Sapim CX-Sprint Straight-Pull Spokes
| Article number: | Spokes |
Sapim CX-Sprint Straight-Pull spokes are designed for riders who need greater stiffness and durability than CX-Ray while maintaining aerodynamic performance. Using a 2.0 - (2.25 x 1.25) - 2.0mm profile, CX-Sprint increases material through the center section to improve strength under higher loads.
With a 2.25 x 1.25mm bladed section and 1430 N/mm² tensile strength, CX-Sprint is well suited for powerful riders, low spoke count wheels, and high-load road, gravel, and MTB builds using straight-pull hub systems.
CX-Sprint fills the gap between lightweight aero spokes and traditional double-butted spokes. For lighter builds, consider Sapim CX-Ray.
- Bladed stainless steel spoke for aerodynamic, high-strength wheel builds
- Increased stiffness and durability compared to CX-Ray
- Cold-forged construction for improved fatigue resistance
- Straight-pull design for modern hub compatibility
- Compatible with standard 14G / 2.0mm interfaces
CX-Sprint Straight-Pull is built for riders who need more stiffness and durability than CX-Ray without giving up aerodynamic performance.
Best suited for powerful riders, low spoke count wheels, and gravel or MTB builds where added spoke strength improves overall wheel stability.
If you are building for minimum weight and compliance, choose CX-Ray. If you prioritize cost and durability over aerodynamics, choose Sapim Race.
Wheelbuilding Notes
The bladed section should be held during tensioning to prevent spoke wind-up. Using a Sapim Bladed Spoke Holder improves accuracy during build.
Need help calculating spoke length? Use the Spoke Length Calculator, or contact our wheel builders.
| Specifications | |
| Weight | ~5.4 - 6.2 g |
| Material | Cold Forged Stainless Steel |
| Head Type | Straight-Pull - 2.0 mm |
| Blade Dimensions | 2.25 x 1.25 mm |
| Profile | 2.0 - (2.25 x 1.25) - 2.0 mm |
| Tensile Strength | 1430 N/mm² |
| Thread | 2.2 x 56 tpi (2.0 mm x 14G) |
Custom Spoke Cutting Available
We can cut CX-Sprint Straight-Pull spokes to order when stock is available within 20 mm of the required length.
For exact lengths or custom builds, contact our wheel builders.
