Schmolke TLO Carbon Seatpost
| Article number: | 011-05-02 |
The Schmolke TLO Carbon Seatpost is handmade in Germany from high-modulus carbon fiber for the perfect balance of comfort and performance. Designed with tuned vertical compliance, it filters road vibration without sacrificing lateral or torsional stiffness, ensuring maximum efficiency and control.
Weighing as little as ~79g, the TLO is among the lightest seatposts available. A sleek, minimalist form enhances any build, while compatibility with 7 x 7, 7 x 9, and 7 x 10 mm saddle rails and an internal Di2 battery mount add modern functionality. Titanium hardware provides secure clamping with long-term durability.
Engineered for dedicated road use, the TLO Carbon Seatpost sets a benchmark for ultralight performance, reliability, and craftsmanship.
| Length | 280 mm | 300 mm | 350 mm |
| Approx. Weight | |||
| 27.2 mm | ~79g | ~83g | ~90g |
| 31.6 mm | ~82g | ~86g | ~95g |
| Intended Use | Road Only | ||
| Saddle Rails | 7 x 7 / 7 x 9 / 7 x 10 mm | ||
| Torque (Saddle Rails) | 5Nm | ||
| Maximum Rider Weight | 220 lbs (100 kg.) | ||
| Insertion Range (Seat Rails to Seat Collar) | |||
| 150 - 200 mm | 160 - 220 mm | 195 - 265 mm | |
Pair the Schmolke TLO Seatpost:
- with the SL 79 Carbon Saddle for a complete ultralight setup.
- For cockpit integration, consider the Roadbar EVO TLO Handlebar.
- Match with the TLO Road Stem for a cohesive Schmolke carbon build
| _____________________: | ____________________ |
| Material: | • Carbon Fibre |
| Rail Compatibility: | • 7 x 7 mm / 7 x 9 mm / 7 x 10 mm |
| Min. Insertion: | • 280 mm (150 mm) | 300 mm (160 mm) | 350 mm (195 mm) |
| Clamping Area: | • 280 mm (150 - 200 mm) | 300 mm (160 - 220 mm) | 350 mm (195 - 265 mm) |
| Max Torque: | • Saddle Rails - 5Nm |
| Saddle Offset: | • 0 mm |
| Rider Weight Limit: | • 220 lbs |
