Wend Waxworks Chain Wax Kit (4 oz. Wax-On / 2.5 oz. Wax-Off)
| Article number: | 002-02-01 |
The WEND CHAIN WAX KIT Contains the following: 1- WEND WAX-OFF, 1-WEND WAX-ON, 1-WEND MICRO TOWEL
Hand Poured in California!
WEND Wax‐On is the first ever “rub‐on”, wax based, chain lubricant. Wax‐On not only keeps your chain clean, its friction reducing additives make for an extremely quiet and efficient drive-train. Wax‐On is quiet, quick, and clean. It is no secret that the most efficient chain lubrication method to date is immersing a chain into a vat of molten paraffin. However, this method is time consuming, temporary, and dangerous. WEND Waxworks set out to create a lube that would perform equal to or better than hot waxing and that would be easy to apply. After two years of development, the R&D at WEND has come up with Wax‐On. Wax‐On is a sophisticated paraffin based formula that includes proprietary friction reducers as well as proven lubricants such as Zinc and Teflon. The application is a cinch as the user simply rubs the wax onto the chains rollers, resulting in a race ready chain in seconds. Overall user satisfaction is high due to the ease of use, product cleanliness, and lubrication performance.
WEND WAX‐OFF is much more than just a chain cleaner. Wax‐Off is a penetrating liquid wax additive that cleans. The cleaner quickly cuts through wax, oil, and dirt leaving your chain sparkling, while the wax penetrates and lubes. WEND Wax‐Off is the perfect way to clean your chain prior to using Wax‐On and aids in extending the life of your drive-train. We are confident once you make the change to WEND you will never look back.
1st at Gravel Worlds
"150 miles of dirt and gravel takes an extreme toll on chain lube, and once I tried Wend Wax I knew it would be the trick for getting through such a challenging day." -Neil Shirley, 2015 Gravel Worlds Champion
WEND CHAIN KIT "HOW-TO"
