White Industries T11 Rear Road Hub
The T11 is White Industries rim brake (non-disc) road hub and is the perfect choice for road builds. Made in our shop from U.S. sourced 6061-T6 aluminum, they’re available in a range of colors, drillings and driver styles.
- U.S. made 6061-T6 aluminum
- Enduro bearings
- Cassette spacer included only on XDR freehub bodies
- Available separately for Shimano HG11 (part# SPACER11)
Specs
- 252g
- 20H, 24H, 28H, 32H, 36H drillings
- Axles: 130mm x 10mm QR
Bearings
- All Enduro ABEC 5 except 3802W (ABEC 3)
Driver Style |
Left hub shell bearing | Right hub shell bearing | Inner driver bearing |
Outer driver bearing |
Shimano Hyperglide 11 speed |
61902-SRS | 61902-SRS | 3802W LLB |
61902-SRS |
Shimano Micro Spline |
3802W LLB |
SRAM XD/XDR |
3802W LLB |
Campy 11 speed |
61902-SRS | 61902-SRS | 3802W LLB | 3802W LLB |
Wheelbuilding specs
Spoke Hole Diameter : 2.3mm
Left flange diameter |
Right flange diameter | Center to left flange |
Center to right flange |
40.5mm |
55mm | 35mm | 18mm |
