Abbey Bike Tools H.A.G. Replacement Parts
$2.00
Article number: 005-05-03
Abbey H.A.G. Replacement Parts are designed to restore proper function to the Abbey Hanger Alignment Gauge without replacing the full tool. These service parts help maintain accuracy and extend tool life in professional workshop environments where alignment tools see regular use.
Why Use Abbey H.A.G. Replacement Parts
Replacing worn or damaged service components is often the most practical way to keep a precision alignment tool working properly. These replacement parts are intended specifically for the Abbey H.A.G. and support long-term workshop use without requiring full tool replacement.
  • Designed specifically for the Abbey H.A.G. Hanger Alignment Gauge
  • Helps maintain alignment tool accuracy and service life
  • Useful for workshop tools that see frequent professional use
  • Allows targeted replacement instead of replacing the full tool
Available Replacement Parts
  • Hardware Kit — Includes small O-ring, large O-ring, and set screw
  • Thread Cap — Replacement threaded cap for the H.A.G.
  • Gauge Stick — Replacement measuring rod for the H.A.G.
Alignment Tool System
These parts are designed for the Abbey H.A.G. Hanger Alignment Gauge, which serves as the primary precision tool in Abbey’s alignment workflow. For quick visual checks and cockpit alignment tasks, see the Abbey preHAG and Abbey Lever Setter.
Compatible Tool
These replacement parts are designed specifically for the Abbey H.A.G. Hanger Alignment Gauge.
