Carbon-Ti X-Hub 56t Freehub Body
$175.00
* Unit price: $155.00 /
Article number: 008-05-04
The Carbon-Ti X-Hub Freehub Body lets you convert compatible X-Hub wheelsets for use with SRAM, Shimano, or Campagnolo 9, 10, 11, or 12-speed cassettes, depending on the selected freehub standard. Each freehub comes pre-assembled with bearings, lip seal, pawls, and springs for a straightforward swap.
Designed for Carbon-Ti 17mm axle hubs manufactured after September 2017, this conversion expands cassette compatibility and gives you more drivetrain setup options. Like all Carbon-Ti components, it is designed and manufactured in Italy.
The 56t freehub versions are compatible with X-Hub SL and Straight Pull Disc or Road hubs produced after September 2017. The 28T version is intended for hubs produced prior to September 2017.
 Drivetrain  9, 10, 11, & 12-Speed Depending on Freehub Standard
 Cassette Campagnolo, SRAM XD/XDR, Shimano HG 10/11-Speed, Shimano Micro Spline
 Hub Compatibility Carbon-Ti X-Hub SL And Straight Pull Disc/Road Hubs With 17mm Axles
 Engagement  56T Hubs After September 2017; 28T Hubs Prior To September 2017
 Weight By Freehub Standard
 SRAM XD ~49g
 SRAM XDR* ~49g
 Shimano 10/11-Spd* ~53g
 Campagnolo ~52g
 MicroSpline** ~61g
* Weight May Change Slightly If A 1.8mm Spacer Is Used Behind The Cassette
** Micro Spline Freehubs Include A Replacement Axle For Hubs Manufactured Prior To March 2020
