Carbon-Ti X-Hub SP Centerlock Front Disc Hub
$214.00
Article number: 10-02-03
Availability: In stock (7)
As an offshoot of exoctic materials manufacturer, LLS Titanium, Italy based Carbon-Ti draws from decades of material science and design experience to bring the cycling community an array of quality components. Since 2005, Carbon-Ti has produced uniquely handsome parts that make no compromises in either weight or performance.
The Straight Pull X-Hub from Carbon-Ti is unquestionably an excellent example of their design and machining prowess. Featuring an ingenious tool-free bearing preload adjustment system, the X-Hub can be adjusted to perfection in seconds by simply turning the clever knurled cone. Expertly machined from 7075 T-6 aluminum, the SP X-Hub is both lightweight and robust, two huge necessities for gram conscious riders who often find themselves pushing their components to the limits. Seamlessly paired with the SP X-Hub Rear Disc Hub, each hub from Carbon-Ti is an ideal way to add a dash of exotic Italian flair while simultaneously ensuring the longevity of your next wheelset.
Weight 92 grams
Bearing Sizes 6803 (2)
Axle Outer Diameter 17mm
Material 7075 T6 aluminum
Brake Rotor Compatibility Centerlock | 6-bolt - w/adapter
