| Article number: |
008-04-05 |
| Availability: |
In stock
With the industry quickly turning more and more to the use of thru axle designs on many frames and forks, having options for tuning your build with quality aftermarket components becomes increasingly important. For those looking to shed grams while simultaneously maintaining an impressive minimalist look, the 12 mm X-Lock is an ideal choice. Available in a plethora of standards, the X-Lock is a performance part sure to find a home on most modern mountain bikes.
The X-Lock 12mm rear thru axle is proudly manufactured in Italy.
| Material |
7075 Aluminum |
| Tool Fitting |
5m Hex |
| Recommended Torque |
Max 10 Nm |
| E-Thru |
Length |
Compatibility |
Thread |
Weight |
| E-Thru |
171mm |
12 x 142 mm |
17mm |
~32g |
| Road (EVO) |
166mm |
12 x 142 mm |
18mm |
~31g |
| Boost |
178mm |
12 x 148 mm |
18mm |
~33g |
| Pitch |
12 x 1.5 mm |
| Interface |
Flat |
| E-Thru |
Length |
Compatibility |
Thread |
Weight |
| Maxle |
174 mm |
12 x 142 mm |
20 mm |
~33g |
| 135 mm |
167 mm |
12 x 135 mm |
20 mm |
~32g |
| 150 mm |
182 mm |
12 x 150 mm |
20 mm |
~34g |
| ABP |
192 mm |
12 x 142 mm |
20 mm |
~35g |
| ABP Boost |
198 mm |
12 x 148 mm |
20 mm |
~36g |
| Pitch |
12 x 1.75 mm |
| Interface |
Flat |
| Scott / X-12 |
Interface |
Length |
Compatibility |
Thread |
Weight |
| Scott |
Flat |
168 mm |
12 x 142 mm |
16 mm |
~32g |
| Road |
Flat |
158 mm |
12 x 142 mm |
16.5 mm |
~34g |
| X-12 (EVO) |
Tapered |
159 mm |
12 x 142 mm |
16.5mm |
~34g |
| Boost |
Tapered |
166 mm |
12 x 148 mm |
17.5 mm |
~34g |
| Pitch |
12 x 1.0 |
