$35.00
Article number: 013-02-05
Fair Wheel Bikes Replacement Brake/Shift Lever Hoods are precision-molded replacement hoods for select Shimano, SRAM, and Campagnolo road brake/shift levers. Each version is shaped for a specific lever body to restore grip, comfort, and control without replacing the full lever assembly.
These hoods are available in a clean black finish only and are sold as a complete left + right pair. They are a practical replacement option for worn, torn, sticky, or deteriorated road lever hoods.
Important Fitment Note: Brake/shift lever hoods are model-specific. Match your lever model carefully before ordering, as similar-looking Shimano, SRAM, and Campagnolo levers may use different hood shapes.
Compatibility / Detail Weight
 Sold As Pair, Left + Right
 Color Black Only
 Material Molded High-Grip Rubber
 Fitment Model-Specific
Shimano
Dura-Ace R9100
— Fits ST-R9100 11-speed mechanical levers
~51g
Dura-Ace 9001
— Fits ST-9001 11-speed levers; not compatible with ST-9000
~53g
Dura-Ace 9000
— Fits ST-9000 11-speed levers; not compatible with ST-9001
~52.5g
Dura-Ace 7900
— Fits ST-7900 10-speed levers
~52.5g
Ultegra R8000
— Fits ST-R8000 11-speed mechanical levers
~52.5g
Ultegra 6800
— Fits ST-6800 11-speed mechanical levers
~53g
Ultegra 6700
— Fits ST-6700 10-speed mechanical levers
~57.5g
Ultegra Di2 6770
— Fits ST-6770 10-speed Di2 levers
~58.5g
105 5700
— Fits ST-5700 10-speed levers
~59.5g
Ultegra 6600 / 105 5600
— Fits ST-6600 and ST-5600 10-speed levers
~60.5g
SRAM
Red22 / Force22
— Fits 11-speed mechanical Red22 and Force22 road levers
~61.5g
SRAM 10-Speed
— Fits Force, Rival, and Apex 10-speed mechanical road levers
~58.5g
Campagnolo
11-Speed EPS
— Fits Campagnolo 11-speed EPS levers
~55g
Super Record 11-Speed
— Fits Campagnolo 11-speed Super Record levers
~58.5g
Super Record 10-Speed
— Fits Campagnolo 10-speed Super Record levers
~59.5g
Looking for SRAM eTap or AXS hoods? These are handled separately. See our SRAM eTap Brake Hood collection for OEM-compatible electronic lever hood options.
Installation Notes
For best fit and durability, we recommend removing the levers from the handlebars before installing new hoods. This reduces the risk of tearing the hood and makes it easier to align the rubber correctly around the lever body.
Installation Step Recommendation
 Lever Prep Remove the lever from the handlebar when possible.
 Lubrication Use rubbing alcohol to help slide the hood into position.
 Alternative A mild soap solution or hairspray may also be used.
 Final Fit Check that the hood is fully seated around the lever body before wrapping the bar.
