Fair Wheel Bikes Replacement Brake/Shift Lever Hoods are precision-molded replacement hoods for select Shimano, SRAM, and Campagnolo road brake/shift levers. Each version is shaped for a specific lever body to restore grip, comfort, and control without replacing the full lever assembly.
These hoods are available in a clean black finish only and are sold as a complete left + right pair. They are a practical replacement option for worn, torn, sticky, or deteriorated road lever hoods.
Important Fitment Note: Brake/shift lever hoods are model-specific. Match your lever model carefully before ordering, as similar-looking Shimano, SRAM, and Campagnolo levers may use different hood shapes.
Looking for SRAM eTap or AXS hoods? These are handled separately. See our SRAM eTap Brake Hood collection for OEM-compatible electronic lever hood options.
Installation Notes
To install we recommend removing the levers from the handlebars before installing new hoods. Installation of the hoods should be done from the rear end of the assembly with the lever removed from the handlebar. This reduces the risk of tearing the hood and makes it easier to align the rubber correctly around the lever body.
Installation Step
Recommendation
Lever Prep
Remove the lever from the handlebar when possible.
Lubrication
Use rubbing alcohol to help slide the hood into position.
Alternative
A mild soap solution or hairspray may also be used.
Final Fit
Check that the hood is fully seated around the lever body before wrapping the bar.
