Fair Wheel Bikes Shift / Brake Replacement Hoods
$35.00
Article number: 013-02-06
Fair Wheel Bikes introduces a new line of premium replacement hoods engineered for compatibility with today’s most common Shimano and SRAM road levers. Designed to match the tactile feel, fit, and durability of the originals, these hoods offer a reliable and cost-effective alternative to OEM options—all in a clean, black finish.
Each pair is precision-molded for a specific brake/shift lever model. Manufactured from durable, high-grip rubber, these hoods are ideal for riders seeking a no-fuss replacement solution that restores comfort and control without compromising aesthetics or performance.
These hoods are available in black only. Sold as a set (left + right).
Note: If you're looking for replacement hoods specifically for SRAM eTap or AXS levers, please see our dedicated SRAM eTap Brake Hood collection for OEM-compatible options.
SHIMANO
SRAM
  • SRAM 10-Speed - For Force / Rival / Apex 10-speed mechanical levers
CAMPAGNOLO
INSTALLATION INSTRUCTIONS
To ensure proper fit and durability, we recommend removing your levers from the handlebars prior to installation. This reduces the risk of tearing and allows for easier positioning.
To aid installation:
  • Use a spray bottle of rubbing alcohol to lubricate the hood
    • Dries tacky for a secure hold
  • Alternatively, a mild soap solution or hairspray may be used
    • Work quickly if using hairspray, as it dries fast.
Compatibility Weight
Dura-Ace 9100 ~51g
Dura-Ace 9001 ~53g
Dura-Ace 9000 ~52.5g
Dura-Ace 7900 ~52.5g
Ultegra 8000 ~52.5g
Ultegra 6800 ~53g
Ultegra Di2 6770 ~58.5g
Ultegra 6700 ~g
Ultegra 6600 / 105 5600 ~g
Ultegra 105 5700 ~g
SRAM Red22 / Force22 ~61.5g
SRAM Red 10 Speed ~58.5g
Campy 11-Speed EPS ~55g
Super Record 11-Speed ~g
Super Record 10-Speed ~g
Material Silicone Rubber
