KCNC 7075 Rear Thru Axle
$40.00
* Unit price: $40.00 /
Article number: 23-04-03
Availability: In stock (2)
Precision machined from 7075 aluminum and vibrantly anodized, KCNC’s Low Profile 12x142mm Thru Axle is an exceptionally light upgrade option. Significantly lighter than OEM and rival companies equivalent options, these axles feature a low profile head that virtually eliminates the hangups on rocks and shrubs. For a sleek profile and lightest possible build these thru axles are the perfect choice. Available in KCNC’s signature colors to match any build theses axles offer a simple, functional, and beautiful option for those looking to upgrade.
Compatibility
KCNC’s thru axles come in several different threading and length options. Please make sure to select the correct axle type to go with your frame. For tool free installation check out KCNC’s Indexing and Quick Release thru axle options.
Check out our blog for better info about which thru axle to use
E-Thru Hub Compatibility Interface Length Thread Pitch Thread Length Weight
161 mm TA 12 x 142 Flat 161mm 12 x 1.5mm 18mm 27 g
171 mm TA 12 x 142 Flat 171mm 12 x 1.5mm 18mm 28 g
Boost 167 mm TA 12 x 148 Flat 167mm 12 x 1.5mm 18mm 28 g
Boost 177 mm TA 12 x 148 Flat 177mm 12 x 1.5mm 18mm 28 g
Maxle / X-12 Hub Compatibility Interface Length Thread Pitch Thread Length Weight
Maxle TA 12 x 142 Flat 173mm 12 x 1.75mm 21mm 29 g
Maxle Boost 180 mm TA 12 x 148 Flat 180mm 12 x 1.75mm 21mm 29 g
Syntace X-12 TA 12 x 142 Tapered 163mm 12 x 1.0mm 18mm 28 g
Material 7075 Aluminum
Tool Fitting 5mm Hex
