Praxis N/W Alloy 1X Direct Mount MTB Chainring
| Article number: | 015-03-04 |
Engineered to tackle the most technical and punishing trails, the Praxis MTN DM1X chainring delivers durability and performance for enduro, downhill, and cross-country riding. Forged and machined from 7075 T6 aluminum then hard anodized for strength, this narrow/wide 1x chainring sheds mud and withstands rock strikes while providing reliable chain retention. Its narrow-wide tooth profile grips the chain without a guide. Lightweight yet burly, the MTB DM 1X keeps you charging on your choice of 10/11/12 speed drivetrains. Praxis creates industry-leading cycling components designed by riders for riders.
Select chainring based on crank and frame compatibility. We're happy to help you choose the right ring for your bike's specs.
| Chain Offset | DMA | DMB | |||
| 3 mm | 0 mm | ||||
| Weight | 30t | 32t | 34t | 36t | |
| ~61g | ~66g | ~72g | ~79g | ||
| Crank Compatibility | SRAM style 3-Bolt Direct Mount | ||||
| Chain Compatibility | 10 / 11 / 12spd Compatible | Shimano / SRAM / KMC | ||||
| Material | Forged / Machined | 7075-T6 Aluminum | Hard Blk Anodized | ||||
| Must use a CLUTCH type rear derailleur (Shim. Shadow or SRAM Type2) | |||||
