Risk Titanium Recessed Brake Mount Bolt RT052 - 6
$11.50
Article number: 017-05-01
The Risk Titanium Recessed Brake Mount Bolt (RT052-6) is a lightweight replacement fastener for mounting rim brake calipers to frames and forks that use recessed brake hardware. Manufactured from corrosion-resistant titanium alloy, it replaces standard steel recessed brake bolts to reduce weight while maintaining secure caliper attachment.
Recessed brake mount bolts are used on modern road frames and forks where the bolt threads into a hidden nut or integrated receiver inside the crown or bridge. This titanium version is ideal for performance builds, wet-climate riding, or any rim-brake setup where durability and serviceability are priorities.
 Weight ~6g
 Length 40 mm
 Material Titanium
 Includes M6 x 40 mm Bolt Nut / M6 Washer
