Risk Titanium Rim Brake Cable Fixing Bolt RT031
$8.00
Article number: 017-05-01
The Risk Titanium Rim Brake Cable Fixing Bolt (RT-031) is a precision replacement fastener for securing brake cables at rim brake calipers. Manufactured from corrosion-resistant titanium alloy, it replaces standard steel cable anchor bolts to reduce weight while maintaining consistent clamping force under braking loads.
Key Features
  • Titanium alloy construction for reduced weight and corrosion resistance
  • Designed for rim brake cable fixing / anchor applications
  • Maintains secure cable retention under braking loads
  • Direct replacement for OEM steel bolts
  • Suitable for road caliper and other rim brake systems using M6 hardware
 Fits M6
 Length 10 mm
 Weight ~2.1g
 Includes 2 - M6 Bolts
