Sapim CX-Ray Straight-Pull Spokes
$3.90
Article number: Spokes
Sapim CX-Ray Straight-Pull spokes are widely regarded as the benchmark for lightweight aerodynamic spokes in high-performance wheel builds. Using a cold-forged 2.0 - (2.3 x 0.9) - 2.0mm bladed profile, CX-Ray combines low weight, excellent fatigue resistance, and proven long-term durability.
The straight-pull design is intended for modern straight-pull hub systems and offers a clean, high-performance option for aero-focused wheel builds.
  • Ultralight bladed stainless steel spoke for performance wheel builds
  • Aerodynamic profile reduces drag compared to round spokes
  • Excellent fatigue resistance for long-term durability
  • Cold-forged construction for strength and consistency
  • Straight-pull design for modern hub compatibility
  • Standard 14G / 2.0mm spoke interface
Sapim CX-Ray Straight-Pull is best suited for riders prioritizing low weight, aerodynamic efficiency, and long-term fatigue resistance.
Ideal for climbing wheels, all-around road builds, lightweight gravel setups, and other performance-focused wheels built around straight-pull hubs.
For more stiffness and durability, choose Sapim CX-Sprint. For a more cost-effective and durable round spoke, view Sapim Race.
Wheelbuilding Notes
Bladed spokes should be held during tensioning to prevent wind-up. Using the Sapim Bladed Spoke Holder improves accuracy during tensioning and truing.
Need help calculating spoke length? Use the Spoke Length Calculator, or contact our wheel builders.
 Weight ~4.4 - 4.6 g
 Material Stainless Steel
 Head Type Straight-Pull - 2.0 mm
 Blade Dimensions 2.3 x 0.9 mm
 Profile 2.0 - (2.3 x 0.9) - 2.0 mm
Spoke Length & Cutting
Sapim spokes are generally stocked in standard lengths. If your required size is unavailable, we may be able to cut and thread from a nearby length when stock allows.
For exact sizing or build guidance, contact our wheel builders.
