Pillar Mega Lite J-Bend / Straight-Pull Spokes
$6.50
Article number: Spokes
Important: These spokes are supplied in limited base lengths and are cut and threaded to order. Include spoke lengths in your order notes.
Pillar Mega Lite spokes are engineered for ultralight performance builds, featuring a bladed profile optimized for minimal weight and aerodynamic efficiency.
Designed for riders prioritizing weight savings, Mega Lite spokes deliver reduced rotational mass while maintaining sufficient strength for performance road use.
Spoke Ordering Guide
Use SpokeCalc and include lengths in order notes. Spokes are cut and threaded to order.
Configuration Options
Available in J-Bend and Straight-Pull.
  • Ultralight bladed spoke design
  • Reduced rotational weight
  • Optimized for high-performance road builds
  • Balanced aero efficiency
Mega Lite is ideal for weight-focused builds where minimizing mass is the primary goal.
For more stability, consider Wing 20. For more durability, see Pillar 1422.
 Weight ~3.5 – 3.8 g
 Material Stainless Steel
 Head Type J-Bend / Straight-Pull
 Blade Dimensions 1.7 x 0.9 mm
