Pillar PSR Wing 20 Straight-Pull Spokes
$3.19
Article number: Spokes
Important: These spokes are supplied in limited base lengths and are cut and threaded to order. You must include your required spoke lengths in the order notes, or specify if threading is not needed.
Pillar PSR Wing 20 spokes are a bladed stainless steel spoke designed for aerodynamic performance and improved torsional stability. Featuring a 2.0 x 1.2 mm blade profile, they provide a balance of weight, strength, and reduced spoke twist during building.
The Wing design resists rotation under tension better than traditional flat spokes, making them a strong choice for consistent builds and long-term wheel stability.
Spoke Ordering Guide
1. Determine Your Spoke Length
Use a Spoke Length Calculator, or contact us.
2. Select Quantity
Order the total number of spokes needed.
3. Add Lengths in Order Notes
Enter lengths during checkout, separating quantities if needed.
Need Help?
Contact our wheel builders.
Configuration Options
Available in Straight-Pull.
  • Bladed 2.0 x 1.2 mm aerodynamic profile
  • Improved torsional stability during tensioning
  • Approx. ~4.3 g weight
  • T302+ stainless steel construction
  • Optimized for performance road and gravel builds
Wing 20 is ideal for aero builds requiring increased stability during build and riding.
For lighter aero options, see Sapim CX-Ray. For higher stiffness, consider CX-Sprint.
 Weight ~4.3 g
 Material T302+ Stainless Steel
 Head Type Straight-Pull
 Blade Dimensions 2.0 x 1.2 mm
