$1,449.00
* Unit price: $1,449.00 /
Article number: 014-05-03
The THM Fibula is an ultra-light carbon rim brake engineered for modern wheel standards and peak rider performance. This latest generation uses resin transfer molding (RTM) to achieve tighter tolerances, improved strength-to-weight, and reduced environmental impact . Weighing in at just 120 g for the front and rear combined (61 g front, 59 g rear), it delivers elite-level stopping power at roughly half the mass of competing systems
Both arms and the return spring are full-carbon, with high-tensile titanium adjusters and hardware. An adjustable cam pivot allows flawless setup across rim widths from 19–30 mm and accommodates tires up to 25 mm without re-clamping. The pull ratio (1:1.5) is precisely calibrated for compatibility with Shimano, SRAM, and Campagnolo levers.
Renowned for its exceptional linear mechanical response—with superior uniformity and modulation—and tested performance comparable to high-end rivals like Dura-Ace, SRAM Red, and Campagnolo Super Record , the Fibula remains the ultralight brake of choice for riders under 110 kg total system weight.
Features:
Resin Transfer Molded Carbon
Full Carbon Construction
Consistent Modulation
Broad Rim Compatibility
Specs:
 Weight ~120g w/o Pads (~61g Front / ~59g Rear)
 Brake Pads Shimano standard brake pad inserts
 Compatible Brake Levers All Rim brake cable pull levers
 Rim Width Up to 30 mm wide
 Rider Weight Limit 110 kg (243 lb)
