10 to 7 Stem Holder
$20.00
Article number: 010-01-08
Have you ever needed to remove a fork, but wanted to leave your bars, stem, spacers and uper headset all on the bike instead of having to find a place to lay everything out, and not have to have your bars and stem just dangling there by your cables/hoses? 10 to 7 came up with a great tool to take away the hassle of a fork removal. The 10 to 7 Stem Holder is simply placed through the top of the stem once the top cap is removed. The shaft of the tool goes through the stem, spacers and headset, down into the head tube of your bike, holding everything in place. There is a groove thoughtfully designed into the shaft as to help with internally routed bikes, so that any lines won't get kinked or damaged. The bottom of the shaft is slightly tapered so that when you reinstall your fork, the tapered portion will sit nicely in the steer tube, allowing you to cleanly push out the tool and easily re-situate the stem and spacers onto your fork's steer tube.
