10 to 7 Thru Axle Holder
| Article number: | 010-01-08 |
You remove a wheel to replace a rotor, cassette, or tire, and then when going to re-install the wheel you cannot figure out where you set the thru axle...can you relate? The 10 to 7 Thru Axle Holder is a cure for this common shop problem. Capable of holding two 12mm, and one 15mm thru axles, this handy little device can easily be mounted by worm drive clamp, or zip tie to the underside of your repair stand head arm, as well as onto the main body of the repair stand. Keeping track of thru axles has never been easier.
