10 to 7 Truing Stand Caliper Holder
| Article number: | 010-01-08 |
On the occasion when you only need to use one side of the calper on your true stand, why use an allen key to move the desired side out of the way when you could use a purpose made tool for the job? That is precisely what the 10 to 7 Truing Stand Caliper Holder was made for. Intended to use with the Park 4 series true stand, this tool mounts to the lower arm of the true stand. Once mounted the stopper can be used to hold back either the left or the right side caliper. Once finished truing the wheel, pull out on the caliper that is being held back to release the stopper(which is cleverly fitted with a return spring) so that it can go back to its reasting position. Simple, functional, awesome.
