Alligator Disc Brake Adapter
| Article number: | 009-03-04 |
Installing a larger diameter disc rotor is the fastest and easiest way to improve braking performance. As riders choose to traverse more aggressive terrain, brake performance becomes ever more crucial. Upgrading from stock rotors can make the difference between having to walk your bike down chunky sections of trail and riding it with confidence. Larger rotors improve brake modulation, which translates to the ability to brake harder and faster without locking up the brakes completely.
The ideal way to adapt an I.S. brake mount fork to a post mount caliper, the Alligator IS/Post disc adapter is a simple and economical option that fits with any build.
Upgrading your front disc rotor has never been easier than fitting a 180mm rotor with the Alligator Post/Post Disc adapter. Don't let undersized rotors hold you back.
| I.S. / Post Compatibility | |
| I.S. Frame / Fork Mount, Post Mount Caliper, 160mm Front / 140mm Rear Rotor | |
| Post / Post Compatibility | |
| Post Mount Fork and Caliper, 180mm Front Rotor | |
| Material | 6061 Aluminum |
| Weight | |
| I.S. / Post | ~27.5g |
| Post / Post | ~35g |
