Ashima Disc Brake Adapter Series
$24.00
Article number: 007-04-03
The Ashima Disc Brake Adapter Series provides precise caliper positioning across modern and legacy frame standards. Each adapter is CNC-machined for accurate rotor alignment and consistent brake performance. Options include Flat-Mount to Post-Mount conversions, IS to Post-Mount interfaces, and Post-Mount adapters for rotor-size changes.
Each adapter is CNC-machined from aluminum alloy for strength and accuracy, ensuring proper rotor alignment and secure caliper positioning. Designed for road, gravel, mountain, and cyclocross bikes, these adapters cover rotor sizes from 140 mm to 180 mm. All mounting hardware is included for straightforward installation.
ORDERING
Adapters are specific to front and rear brakes and rotor diameter. Please take care when ordering to ensure you receive the correct adapter.
Frame / Fork Compatibility Flat Mount
Caliper Compatibility Post Mount Caliper
Fits Compatibility Weight
AU41 Front - 140 mm Rotor ~57g
AU43 Rear - 140 mm Rotor ~41g
AU42 Front - 160mm Rotor ~70g
AU44 Rear - 160mm Rotor ~50g
Frame / Fork Compatibility I.S. Mount
AU01 Front - 160 mm Rotor ~22g
  Rear - 140 mm Rotor
AU02 Rear - 160 mm Rotor ~27g
AU03 Front - 180 mm Rotor ~32g
AU04 Rear - 180 mm Rotor ~39g
 Material Aluminum (Steel Bolts)
