Alligator Superior Shine 31 Strand Cable
$8.00
Article number: 009-03-05
Alligator Superior Shine 31 Strand Cable is the polished version of Alligator’s stainless 31-strand brake and shift cable. The die-drawn, highly polished surface is designed to reduce friction through housing without relying on a temporary coating that can wear away over time.
Available in road brake and shift versions, Superior Shine is the better Alligator cable choice when the build calls for smoother cable movement, refined lever feel, and a cleaner long-term service setup.
Application Notes
Select the correct brake or shift version for your drivetrain or brake system. Superior Shine cables are intended for modern mechanical brake and shift systems from Shimano, SRAM, and Campagnolo, but the correct cable head and application must be matched before installation.
 Cable Weight Diameter Length
 Brake ~24g 1.5 mm 1700 mm
 Shift ~15g 1.1 mm 2000 mm
 Material Stainless Steel
 Finish Die-Drawn / Highly Polished
 Compatibility Shimano, SRAM, And Campagnolo Options
 Sold As Individual Cable
Service Notes
Superior Shine is the higher-finish option in Alligator’s 31-strand cable family. For a lower-cost alternative, see the Alligator Slick 31 Strand Cable. For complete shift housing replacement, compare the Alligator SuperLight+ Shift Housing / Cable Kit, or use KCNC Cable Tips to finish the installation.
