Ashima Rotor Bolt Set
$16.00
Article number: 007-04-02
The Ashima Rotor Bolt Set provides reliable rotor fastening in two material options—7075 aluminum for low weight and steel for maximum durability. Both variants use standard M5 × 10 mm threads and Torx drive heads for secure installation. Aluminum sets include 6 bolts for a single rotor; steel sets include 12 bolts for two rotors, supporting road, gravel, and MTB use. Use a medium‑strength threadlocker and torque to your brake manufacturer’s specification (commonly ~4–6 Nm).
Aluminum (7075):
~6.5 g per set (one rotor)
T20 Torx head
optimized for weight‑conscious builds and XC/light‑duty
applications up to 160 mm rotors.
Steel:
~24 g per set of 12 (two rotors)
(~12g per rotor(6pcs))
T25 Torx head
best for long‑term durability and larger rotors.
Fit & Use
  • Rotor standard: 6‑bolt ISO rotors
  • Thread: M5 × 10 mm (fits most 6‑bolt hubs/rotors)
  • Always follow hub/rotor maker torque specs; apply medium threadlocker; tighten in a star/alternating pattern.
Aluminum - Sold In Set Of 6
 Weight ~6.5g (Set)
 Material 7075 Aluminum
 Thread M5 x 10 mm
 Tools T20 Torx
 Colors Black / Blue / Gold / Red
Steel - Sold in set of 12
 Weight ~24g (Set of 12 bolts)
 Material Steel
 Thread M5 x 10 mm
 Tools T25 Torx
