Cane Creek eeBrake Ltd. Ed. Brakeset
Article number: | 005-02-03 |
Limited Edition G4 eeBrake Brakeset
The **Cane Creek G4 eeBrake Limited Edition** continues the benchmark performance of the G4 platform in unique, collectible finishes.
Available as either **Direct Mount (~150.5 g per pair)** or **Regular Mount (~167 g per pair)**, this set offers elevated functionality with standout aesthetic touches.
Same engineering excellence: CNC‑machined 7075‑T6 aluminum linkage, 6/4 titanium hardware, and IGUS bushings deliver a refined power curve and superb lever feedback. Flange‑less bushing surfaces and the patented notch‑and‑groove pad carrier offer fast, tool‑free pad swaps between carbon and alloy rims.
Compatible with rims from 19–28 mm (max tire size ~30–31 mm) and short‑reach brake levers (39–49 mm), works seamlessly with Shimano, SRAM, and Campagnolo setups. Backed by Cane Creek's 3‑year warranty.
Need another version?
Choose the Direct Mount G4 eeBrake
or the Standard Mount G4 eeBrake.
Specs | ||
Mount Type (set) | Direct Mount or Regular Mount | |
Weight | ~150.5 g (Direct Mount) | ~167 g (Regular Mount) |
Reach | 39–49 mm (Short‑Pull Levers) | |
Rim/Tire Compatibility | 19–28 mm rims / max ~30–31 mm tires | |
Material | 7075‑T6 Aluminum | Titanium / Stainless steel |
