Cane Creek Handlebar Tape
$35.00
Article number: 005-04-00
The Cane Creek Handlebar Tape is a two‑option bar wrap system designed to meet different riding styles: the Suede Flanders with 3.0 mm plush padding for comfort, and the PU‑coated Liège with 2.5 mm thickness and textured surface for grip and control in varied conditions.
Each tape set includes two 200 cm rolls, bolt‑on bar end plugs, and high‑stretch finishing tape — sufficient to wrap a standard drop‑style handlebar. Width is 30 mm, ensuring compatibility with most modern road and gravel bars.
The Liège version’s PU‑coated, cross‑hatched surface provides enhanced grip even when wet or muddy — a strong advantage for gravel, cyclocross, or all‑weather road riding. Its lower profile maintains direct bar feedback and control while still offering a modest increase in cushioning over bare bars.
 Roll Length 200 cm per roll
 Width 30 mm
 Variant Surface Material Thickness
  -Flanders Suede texture 3.0 mm
  -Liège PU‑coated, cross‑hatched 2.5 mm
 Backing / Adhesive Smart Gel backing – reusable / repositionable
 Included in Package 2 rolls tape, bar‑end plugs, finishing tape
