Carbon-Ti Aero Centerlock X-Rotor
$249.00
Article number: 007-01-03
The Carbon-Ti X-Rotor Aero Centerlock Rotor is engineered to reduce aerodynamic drag while maintaining consistent, high-performance braking. Built around a carbon fiber spider derived from the X-Rotor SteelCarbon 3, the structure is refined to improve airflow and reduce turbulence at speed.
Paired with a precision laser-cut stainless steel braking track, the X-Rotor Aero delivers reliable stopping power with effective heat management, making it well-suited for performance road and fast gravel applications.
The rotor features a CNC-machined rounded edge profile to meet UCI safety requirements, reducing sharp edges while maintaining structural integrity. A Centerlock interface with included lockring ensures straightforward installation and secure mounting.
Aero-Optimized Carbon Spider
Carbon fiber structure shaped to reduce drag and improve airflow efficiency without compromising braking stiffness.
Stainless Steel Braking Track
Laser-cut and precision-finished braking surface for consistent power, modulation, and heat dissipation.
Titanium Hardware
Grade 5 titanium rivets and washers provide high strength, corrosion resistance, and reduced weight.
UCI-Compliant Edge Design
CNC-rounded rotor edges improve safety while maintaining structural performance.
Options
Available in 140mm and 160mm diameters. Centerlock lockring included.
Specs
 Fits 140mm 160mm
 Total Weight ~98g ~123g
 Rotor Weight ~73g ~98g
 Lockring Weight ~25g
Materials
 Rotor Stainless Steel / Carbon Fiber / Grade 5 Titanium
 Lockring 7075 Aluminum / Titanium
Best suited for performance road and fast gravel riders looking to reduce aerodynamic drag without sacrificing braking consistency. Ideal for builds focused on weight savings, efficiency, and high-speed stability.
Related Upgrades
Pair with a lightweight disc brake pad upgrade for improved modulation and reduced noise, or explore high-performance hub options to complete your wheel system.
