Carbon-Ti Small Head Torx Bolt
$4.00
Article number: 008-05-04
The Carbon-Ti Small Head Torx Bolt is a lightweight M5 × 14mm aluminum bolt designed for bottle cages and other compatible bicycle components. Its compact 9.5mm-diameter head provides a clean, low-profile appearance for performance builds where both weight and finishing details matter.
CNC-machined from high-strength AL7075-T6 aluminum, the bolt uses a T20 Torx interface for secure tool engagement. Fair Wheel Bikes currently offers the M5 × 14mm version in red.
Small-Head Design
The recessed pan head measures 9.5mm in diameter, creating a compact appearance suited to lightweight bottle cages and other compatible components.
AL7075-T6 Construction
High-strength aluminum construction reduces weight while providing the precision and durability required for properly specified low-load bicycle applications.
T20 Torx Interface
The Torx socket provides positive tool engagement during careful installation and removal.
Red Anodized Finish
Currently available from Fair Wheel Bikes in red for coordinating with Carbon-Ti components and custom build accents.
Size M5 × 14mm
Head Style Small-Head Recessed Pan
Head Diameter 9.5mm
Tool Interface T20 Torx
Material AL7075-T6 Aluminum
Weight ~1.0g Each
Color Red
Suggested Applications Bottle Cages and Other Compatible Components
Sold As Individual Bolt
Installation Note: Verify the required bolt diameter, thread length, head clearance, and torque specification for your component before installation. Aluminum bolts should not be substituted for structural or safety-critical hardware unless expressly approved by the component manufacturer.
