Carbon-Ti X-Hub SP Boost Rear Disc Hub
| Article number: | 008-05-02 |
As an offshoot of exotic materials manufacturer LLS Titanium, Italy based Carbon-Ti draws from decades of material science and design experience to bring the cycling community an array of quality components. Since 2005, Carbon-Ti has produced uniquely handsome parts that make no compromises in either weight or performance.
Carbon-Ti uses a solid block of Al7075-T6 aluminum, which is meticulously CNC machined to achieve an incredibly light weight while maintaining an impressive stiffness-to-weight ratio hub. The 17mm axle, also made of Al7075-T6 aluminum, has a variable wall thickness to keep the weight low while retaining strength in higher stress areas. This axle rides on two high-quality sealed bearings, with externally adjustable preload courtesy of Carbon-Ti's Bearing Preload System Tuning (BPS). This preload system, which consists of a machined dial and grub screw, makes hub adjustments quick and easy. Titanium teeth keep the weight of the freewheel mechanism low, it contains 56 teeth with 4 points of engagement. The hubs are available in either Shimano 11spd MTB, MicroSpline or SRAM XD freehub standards and are interchangeable. These boost hubs come in at a very impressive 183 grams for the XD version, 186 grams for the Shimano version, and are 100% made in Italy. With the combination of its light weight and robust build, Carbon-Ti's X-Hub SP Boost hubs should be at the top of the list for gram-conscious riders who push their components to the limit.
WHEEL BUILDING
Trust a skilled wheelbuilder for your Carbon-Ti built wheels. Contact us for custom wheels, we offer expert service and rim / spoke advice.
| X-Hub | |
| Weight | ~185g |
| Spoke Holes | 24h / 28h |
| Axle Standard | 12 x 148 mm |
| Bearing Size | 6803 - (1) / 6903 - (1) |
| Brake Interface | 6-bolt |
| --Wheel Building Dimensions-- | ||
| LEFT | RIGHT | |
| Flange Diameter | 48 mm | 54.5 mm |
| Center to Flange | 39 mm | 22 mm |
| Spoke Hole Offset | 2.0 mm | |
| Spoke Hole Diameter | 2.5 mm | |
