Chaser Sports Centerlock Adapter
$19.00
Article number: 010-01-09
Unlock the weight savings of 6-bolt rotors—without the usual penalty. The Chaser Centerlock Adapter lets you run lighter 6-bolt rotors on centerlock hubs while minimizing the extra grams typically added by standard adapters.
Precision-machined from 7075-T6 aluminum, this adapter delivers exceptional strength at a fraction of the weight—up to 50% lighter than many competing options. It’s the ideal upgrade for riders who care about every gram but refuse to compromise on reliability.
Key Features:
  • Ultralight design: Up to half the weight of typical centerlock adapters
  • Premium construction: CNC-machined from high-strength 7075-T6 aluminum
  • Wide compatibility: Works with 12mm–20mm thru-axles and quick-release setups
  • Performance-focused: Retain the benefits of lightweight 6-bolt rotors on centerlock hubs
  • Precision fit: Secure, stable interface for consistent braking performance
If you’re chasing the lightest possible setup, this is one of the smartest upgrades you can make—small part, big impact.
Lockring not included. Click here to see Chaser Sports Rotor Lockrings.
 Rotor Fitment 6-Bolt ISO Rotor To Centerlock Hub
 Hub Compatibility 12mm / 15 mm / 20 mm Thru-Axle And Quick Release
 Minimum Rotor Thickness 1.6 mm At Bolt Flange
 Maximum Rotor Size 203 mm
 Weight ~8g
 Material 7075-T6 Aluminum
 Recommended Torque 40 Nm
