Chaser Sports Mount For Integrated Bars
| Article number: | 010-01-09 |
The Chaser Sports Integrated Computer Mount is CNC-machined from lightweight yet durable 7075 aluminum for excellent strength with minimal weight. Its slim, low-profile design creates a clean cockpit appearance while helping preserve an aerodynamic profile.
On the underside, the mount includes an integrated attachment point for a GoPro-style accessory or bike light, allowing you to easily add extra accessories without cluttering your handlebars.
Despite its minimal design, the mount supports up to 500 grams, providing plenty of strength for your cycling computer and additional accessories.
It is compatible with integrated handlebar systems that feature underside mounting bolts, using M4 or M5 hardware with bolt hole spacing between 10 mm and 36 mm, making it suitable for a wide range of modern integrated cockpits.
| Weight | ~26.4g |
| Total Length | 129mm |
| Compatibility | For Integrated Handlebars With Hole Spacing 10mm-36mm, M4/M5 |
| Copmuter Compatibility | Comes With Garmin, Wahoo, and Bryton Bases. |
| Material | Machined 7075 Aluminum |
