Chaser Sports Front Flat Mount Disc Brake Mount
$24.00
Article number: 010-01-09
Chaser Sports Front Flat Mount Disc Brake Mount is a lightweight front flat mount brake adapter for modern road, gravel, and all-road disc brake setups. CNC-machined from 7075-T6 aluminum, it offers a lighter and cleaner alternative to many stock front brake adapters.
Available for standard front flat mount 140/160 mm rotor setups and a dedicated Specialized Tarmac SL8 / Aethos fit option, this adapter is built for riders refining the small details of a lightweight custom build.
Compatibility Note: This is a front flat mount disc brake adapter. The standard version is for compatible 140/160 mm front flat mount setups. The Aethos / Tarmac SL8 version is only for Shimano / SRAM 160 mm rotor setups on Specialized Aethos and Tarmac SL8 road bikes.
Chaser Sports Front Flat Mount Disc Brake Mount Details
 Mount SL8 / Aethos 140 / 160 mm
 Weight ~7.2 g ~7.9 g
 Brake Mount Type Front Flat Mount
 Frame-Specific Option Specialized Tarmac SL8 / Aethos 160 mm
 Adapter Material 7075-T6 Aluminum
 Hardware Ti Alloy Fixing Bolts, T25
 Manufacturing CNC-Machined
 Recommended Torque 6–8 Nm
Why Use This Adapter?
Small hardware parts can make a noticeable difference on a detailed lightweight build. This Chaser Sports adapter reduces weight compared with many stock brake mounts while keeping the fit clean and the installation straightforward.
Fit Notes
Choose the standard 140/160 mm version for compatible front flat mount setups. Use the Tarmac SL8 / Aethos version only when matching those specific Specialized frames. After installation, confirm rotor clearance, pad alignment, bolt engagement, and brake function before riding.
