Chaser Sports Wahoo Titanium Axle
| Article number: | 010-01-09 |
Upgrade your Wahoo Speedplay pedals with precision-engineered Chaser Ti spindles—designed to cut weight, boost performance, and elevate your bike’s look.
Crafted from high-grade titanium, these replacement spindles drop approximately 50g from Speedplay Comp pedals and 40g from Speedplay Zero pedals, helping you achieve a lighter, more responsive ride without compromising strength.
Often overlooked, the spindle is one of the most effective places to trim excess weight—and Chaser makes it easy.
Key Features:
- Significant weight savings: ~50g (Comp) / ~40g (Zero)
- Premium titanium construction: Strong, lightweight, and corrosion-resistant
- Sleek finishes: Available in Black, Gold, or Rainbow
- Performance-focused upgrade: Reduce rotational weight for improved efficiency
- Rider weight limit: 180 lbs (82 kg)
- Sold as a set (pair)
Lightweight, durable, and undeniably stylish—Chaser Ti spindles are one of the simplest upgrades you can make for a faster, cleaner setup.
