ENVE CIM Top Load Cage
| Article number: | ENVE-2-5 |
The ENVE C.I.M. Top Load Bottle Cage combines secure bottle retention with a lightweight composite construction for road, gravel, and mountain bike use. Its Carbon Injection Molded construction uses long carbon-fiber-reinforced polyamide to provide the stiffness and controlled flex needed to hold a bottle securely over rough surfaces.
Full-contact rails and a tuned grip help prevent bottle creep and ejection while retaining conventional top-loading access. At approximately 31g, the C.I.M. provides a lightweight alternative to a traditional composite cage without requiring a full carbon construction.
Why Use The ENVE C.I.M. Bottle Cage
The C.I.M. is designed for riders who want dependable bottle retention across changing terrain in a simple top-load cage that remains lightweight and durable.
- Full-contact rails help reduce bottle movement and ejection
- Tuned grip balances bottle retention with access
- Composite injection-molded construction
- Suitable for road, gravel, and mountain bike applications
- Conventional top-loading bottle access
- Approximately 31g
- Made in Utah
