$975.00
Article number: ENVE-Rims
ENVE G23 700c Gravel Rim is a lightweight carbon gravel rim built for riders who want fast acceleration, efficient climbing response, and dependable tubeless performance on mixed surfaces. With a 23mm internal width, 25mm depth, and hookless bead design, the G23 is optimized around modern gravel tires while keeping overall rim weight exceptionally low.
The G23 is best suited to gravel and mixed-surface builds using tubeless-ready tires in the 35mm to 45mm range, with 40mm tires at the center of its design intent. Its molded bead-lock and wide hookless profile are designed to improve tire retention and reduce pinch-flat risk on rough terrain.
Why Use The ENVE G23 Rim
The G23 is intended for gravel riders who want a light, responsive carbon rim without giving up modern tubeless security, tire volume support, or control on rough roads and variable surfaces.
  • 23mm internal width designed around modern gravel tire profiles
  • Very low ~330g rim weight for quick acceleration and climbing response
  • Hookless tubeless bead profile helps reduce pinch-flat risk
  • Molded bead-lock supports secure tubeless tire fit
  • Optimized around 35mm to 45mm gravel tires, with 40mm as a primary focus
 Specification
 Intended Use Gravel / Mixed-Surface
 Wheel Size 700c
 Approximate Weight ~330g
 Rim Depth 25 mm
 External Width 31.5 mm
 Internal Width 23 mm
 ERD 608 mm
 Hole Count 24 Hole
 Bead Type Hookless
 Tire Type Tubeless Ready
 Recommended Tire Width 35 mm - 45 mm
 Minimum Compatible Tire Width 28 mm Tubeless Ready
 Design Focus Tire Width 40 mm
Included
G23 Tubeless Kit
26.5 mm Tubeless Tape
47 mm Tubeless Valves
Brass Nipples
Build Notes
The G23 should be positioned as a lightweight gravel-specific rim rather than a road-all-road crossover rim. Its 23mm internal width and low rim weight make it an excellent choice for fast gravel builds using modern tubeless tires, especially around the 40mm range.
For complete custom wheel planning, start with our Custom Wheels service or contact us for spoke and hub recommendations.
Related Options
Need setup parts? Add ENVE Tubeless Tape and ENVE PRV Tubeless Valves. Planning a full build from the ground up? Visit our Custom Wheels page.
