ENVE x Reform Seymour Saddle
| Article number: | ENVE-4 |
The ENVE x Reform Seymour Saddle approaches saddle fit differently from a conventional fixed-shape performance saddle. Reform's patented Thermo-Moldable Technology allows the saddle to be molded while the rider is positioned on the bike, creating a rider-specific contact surface intended to distribute pressure more evenly across the saddle.
The Seymour combines this moldable platform with a lightweight carbon shell and carbon monocoque rail structure. Its 142mm width and 252mm length provide a performance-oriented shape, while a durable microfiber cover provides the finished riding surface.
Why Use The ENVE x Reform Seymour Saddle
Rather than requiring the rider to adapt entirely to a predetermined saddle shape, the Seymour allows its contact surface to be thermo-molded to the individual rider while installed on the bicycle.
- Patented Reform Thermo-Moldable Technology
- On-bike molding creates a rider-specific saddle profile
- Carbon shell and carbon monocoque rail structure
- Performance-oriented 142mm x 252mm dimensions
- Durable, grippy microfiber covering
- Made in Canada
Thermo-Moldable Fit
The defining feature of the Seymour is its ability to be shaped to the rider rather than remaining permanently fixed in its original form. Reform's molding process is performed with the saddle installed on the bicycle so the finished contact surface reflects the rider's position and pressure distribution.
The saddle uses oversized 7 x 10mm carbon rails. Verify seatpost clamp compatibility with oval carbon rails before installation.
