ENVE x Selle Italia SLR Boost 3D Kit Carbonio Superflow Saddle
$450.00
Article number: ENVE-4
The ENVE x Selle Italia SLR Boost 3D Kit Carbonio Superflow combines the compact SLR Boost platform with 3D-printed padding and lightweight carbon rails. Manufactured by Selle Italia, its Carbon DLS construction creates differentiated cushioning zones that vary support across the saddle rather than relying on a uniform layer of traditional foam.
The short 248mm profile and Superflow center opening are designed around performance-oriented road positioning, while the 3D structure provides progressive support across changing riding positions. Two widths allow riders to select the appropriate fit without changing the basic saddle platform.
Why Use The SLR Boost 3D
The SLR Boost 3D is intended for riders who want a lightweight performance saddle while using a more sophisticated approach to pressure distribution and cushioning than conventional foam padding.
  • Carbon DLS 3D-printed padding creates differentiated support zones
  • Compact 248mm SLR Boost profile
  • Superflow center opening reduces material through the central contact area
  • Lightweight 7 x 9mm carbon rails
  • Available in 130mm and 145mm widths
  • Approximately 166g to 171g depending on width
Specification 130mm 145mm
Dimensions 130 x 248mm 145 x 248mm
Approximate Weight 166g 171g
Padding Carbon DLS 3D Printed
Rail 7 x 9mm Carbon
Center Opening Superflow
Intended Use Road / Performance
Fit And Compatibility
The saddle is available in 130mm and 145mm widths while maintaining the same 248mm length. Because it uses oversized 7 x 9mm carbon rails, verify that the seatpost clamp is compatible with oval carbon saddle rails before installation.
