Fair Wheel Bikes Ceramic Bottom Bracket For 30mm Spindles
$140.00
Article number: 012-06-02
Experience world-class drivetrain efficiency with the Fair Wheel Bikes Ceramic Bottom Bracket, developed in collaboration with HSCeramics to deliver exceptional performance, longevity, and precision for 30 mm spindle cranksets. Engineered for riders who demand the absolute best, this bottom bracket combines ultra-low-friction ceramic bearings with impeccably machined cups to create a smooth, responsive, and durable interface between your frame and crank.
Key Features
• Premium HSCeramics Bearings
Designed for minimal rolling resistance and maximum durability, these high-grade ceramic bearings offer long service life and noticeably improved efficiency under load.
• Precision-Machined, High-Tolerance Cups
Each set is built to exacting tolerances to ensure perfect alignment, silent operation, and reliable performance—even under the most demanding riding conditions.
• Broad Frame Compatibility
Available for the industry’s most common and performance-focused bottom bracket standards:
T47 (internal & external depending on variant)
PF30 / 386EVO
BB86
BSA threaded
• Optimized for 30 mm Spindles
Ideal for modern cranksets that utilize oversized spindles for improved stiffness-to-weight ratios, ensuring efficient power transfer and a responsive pedal feel.
• Smooth, Quiet, and Efficient
Reduced friction means quicker spin-up, quieter rotation, and better performance during high-power efforts, sustained climbs, or long-distance events.
• Engineered for Real-World Durability
Advanced sealing and material selection keep contaminants out while maintaining ultra-smooth operation, whether you're racing, training, or exploring rough conditions.
Elevate your drivetrain with a bottom bracket engineered for speed, precision, and longevity.
The Fair Wheel Bikes x HSCeramics Bottom Bracket brings pro-level performance to any build running a 30 mm spindle.
 BB Standard T47-In T47-Ex PF30/386 BB86 BSA
 Spindle 30 mm
 Weight ~ 90.6g ~ 87.8g ~ 79.6g ~ 57.7g ~ 69.8g
 Shell I.D. 47mm 47mm 46mm 41mm 41mm
 Installation Tool Included T47 16 Notch Bearing Press Bearing Press Bearing Press
 Material Delrin Thermoplastic - Si3N4 Ceramic Hybrid - Aluminum
