Far and Near Housing Covers
| Article number: | 018-04-02 |
Far and Near Cable Housing Covers protect your frame from cable rub while eliminating unwanted housing rattle. Made from high-quality silicone—the same material used in Far and Near brake hoods—these covers provide a secure, flexible interface between housing and frame contact points.
Each cover is split along its length for easy installation without removing cables, making them ideal for both new builds and quick upgrades. Available in matching anodized color options, they add both functional protection and subtle visual detail.
- Preventing cable rub on painted or carbon frames
- Eliminating housing rattle on road, gravel, and MTB bikes
- Quick installation without disconnecting cables
- Protecting high-contact areas on internally or externally routed frames
- Adding subtle color accents to cable routing
Installation Notes
Installation requires no cable removal. Simply open the split cover and place it over the housing at contact points. The silicone material grips securely, preventing movement while maintaining flexibility for steering and suspension travel.
Pairs Well With
- Cable Ferrules – clean housing termination for a complete setup
For best results, combine housing covers with quality cable systems to achieve quiet operation, smooth routing, and long-term frame protection.
