Galfer Disc Road / Gravel Centerlock Rotor
| Article number: | 021-06-01 |
The Galfer Road/Gravel Centerlock Rotor delivers dependable braking performance in a lightweight package for road and gravel bikes. Precision laser-cut from high-carbon stainless steel, Galfer's signature Wave® design reduces unnecessary weight while improving heat dissipation for consistent braking on long descents and demanding rides.
At 1.8 mm thick, the rotor provides reliable pad contact and compatibility with most modern road disc brake systems. Its low weight, controlled modulation, and proven durability make it suitable for race bikes, all-road builds, and everyday performance-focused setups.
Compatibility Note: Designed for Centerlock disc brake hubs. Confirm rotor size, frame and fork clearance, brake caliper requirements, brake-pad compatibility, and manufacturer restrictions before ordering.
