Gelu R-1 Saddle
| Article number: | 002-03-02 |
The Gelu R-1 is an lightweight carbon saddle weighing in at under 60g. Its reinforced carbon shell features extended, oversized rails for increased adjustment range and durability, with a continuous rail structure extending beneath the nose.
A reinforced teardrop-shaped central cutout reduces perineal pressure while maintaining shell stiffness. Integrated mounting depressions, reinforced cutout edges, and a rear structural carbon blade further increase rigidity and durability.
| Weight | ~57g (Matte 3k version) |
| Construction | Carbon |
| Widths | 127 mm |
| Length | 246 mm |
| Nose Width | 40 mm |
| Rail Diameter | Oval 6.5 x 8.5 mm |
| Use | Road, Mtn, Gravel, Cyclocross |
| Rider Weight Limit | 115 kgs (253 lbs) |
