Gemini Älsak Round Carbon Seatpost
The Gemini Älsak Round Carbon Seatpost is a configurable carbon seatpost for frames using standard round seatpost diameters. Each post is configured by diameter, layup, length, and finish, so fit and availability should be confirmed before ordering.
Configuration & Ordering
Älsak Round posts are special-order items. Final compatibility, pricing, finish availability, and lead time are confirmed through Fair Wheel Bikes before ordering.
Looking for a standard stocked configuration? See the Gemini Älsak Seatpost page for our stocked 27.2 mm UD Matte Lightweight seatpost.
Note: Product finish options can incur an upcharge.
Seatpost Compatibility
Round Seatpost Frames
Designed for frames using standard round seatpost diameters. Confirm your exact frame specification before ordering, as round posts are not interchangeable across all frame sizes and designs.
Diameter
Available in standard round diameters such as 27.2 mm, 30.9 mm, and 31.6 mm. Confirm your frame’s required seatpost size before ordering.
Configuration Options
Finish
Finish options include UD Matte (standard)
Upcharge:
UD Gloss, 12K Matte, and 12K Gloss.
Layup
Choose from Lightweight or Performance carbon layup options, depending on rider needs, use case, and availability.
Length
Length options: 250 mm, 300 mm, 350 mm, and 400mm. Confirm saddle height, exposed post length, and minimum insertion before ordering.
Clamping Area
250 mm: 100 - 145 mm
300 mm: 145 - 220 mm
350 mm: 190 - 265 mm
400mm: 235 - 310 mm
Before Ordering
Confirm your exact seatpost diameter, frame model, required insertion depth, saddle height, saddle rail type, and preferred finish. Round seatposts must match the frame’s specified diameter and clamp requirements.
Looking for a standard stocked configuration? See the Gemini Älsak Seatpost.
Confirm Fit & Availability
Call (520) 624-3045 or email [email protected] for compatibility, lead time, and final pricing.
