Gemini Headset Cover 1-1/4"
$50.00
The Gemini 1-1/4 Headset Cover is used to adapt compatible Gemini integrated handlebars to frames using 1-1/4 headset routing systems. This page separates the ICR internal routing and ECR / standard routing versions so the correct cover can be selected before ordering.
Compatibility & Ordering
Headset covers are frame- and routing-specific. Confirm the bike model, model year, steerer/headset standard, routing style, and intended Gemini handlebar before ordering.
1-1/4 Cover Options
ICR Internal Routing 1-1/4
For frames using integrated cable routing through the upper headset assembly.
Compatible Frames:
Giant Defy
Giant Propel
Giant TCR
Scott Addict 2024
ECR / Standard Routing 1-1/4
For compatible 1-1/4 systems using standard or external cable routing instead of full internal headset routing.
Compatible Frames:
Giant TCR Pre-2024
Scott Contessa
Before Ordering
Do not select by steerer size alone. Routing type matters. A 1-1/4 ICR cover and a 1-1/4 ECR cover are not interchangeable if the frame’s headset routing differs.
Confirm Fit & Availability
Call (520) 624-3045 or email [email protected] to confirm frame compatibility, routing type, handlebar fit, and availability.
