Gemini Headset Cover 1-1/8"
The Gemini 1-1/8 Headset Cover is used to pair compatible Gemini integrated handlebars with frames using 1-1/8 headset routing systems. This page separates the ICR internal routing and ECR / standard routing versions so the correct cover can be selected by frame and routing style.
Compatibility & Ordering
Headset covers are frame- and routing-specific. Confirm the exact frame model, model year, headset standard, cable routing type, and intended Gemini handlebar before ordering.
1-1/8 Cover Options
ICR Internal Routing 1-1/8
For compatible frames using fully integrated headset cable routing.
Compatible Frames:
ENVE Melee / Fray / MOG
Factor Ostro VAM / Ostro Gravel
OPEN U.P. / WI.DE.
Trek Madone Gen 8 / Émonda SLR
Specialized Tarmac SL8
Additional Compatible Frames
Aurum Mantle
Bianchi Specialissima RC
Cannondale Supersix
Colnago C68
Colnago V5RS
Megamo Silk
Orbea Orca
Parlee RZ7
Pinarello Dogma F
Time ADHX 45
Wilier Cento 10 ACR
3T Strada / RaceMax 2
Basso SV
Basso Palta III
Cervélo Soloist
Cervélo Caledonia 5
Fuji Transonic
Look 785 Huez
SEKA Spear
ECR / Standard Routing 1-1/8
For compatible frames using standard or semi-integrated cable routing systems.
Compatible Frames:
OPEN U.P.
Specialized Aethos
Specialized Crux
Factor Ostro VAM 2020
3T Exploro RaceMax
Officina Mattio OM SL
Cervélo Áspero ECR
Before Ordering
Do not select by frame brand alone. Many brands use different covers across model years, routing styles, and headset systems. Confirm model year and routing type before ordering.
Confirm Fit & Availability
Call (520) 624-3045 or email [email protected] to confirm frame compatibility, routing type, handlebar fit, and availability.
