K-Edge Offset Spacer For Garmin 1050
$22.00
Article number: 002-05-03
The K-Edge Garmin Edge 1050 Spacer upgrades compatible K-Edge computer mounts to accommodate the larger Garmin Edge 1050. Precision-machined from lightweight 6061-T6 aluminum, it moves the Garmin insert outward to provide the additional clearance needed while allowing you to continue using your existing mount.
Weight ~8.5 g
Material 6061-T6 Aluminum
Computer Compatibility Garmin Edge 1050
Included
Contents Computer Mount Spacer / Mounting Bolts
