KCNC Indexing Rear Thru Axle
$30.00
$20.00
* Unit price: $20.00 /
Article number: 021-04-03
With the introduction of their 12 x 142 thru axle skewers, KCNC looks to set themselves apart with a unique style and mechanical advantage over other aftermarket skewers. Equipped with an easy to use system for dialing in the perfect skewer angle for your particular frame, simply press the red button in the center of the skewer handle and rotate the cam into any desired position in seconds. Additionally, each KCNC 12 x 142 thru axle skewer utilizes a free-floating knurled endcap, coupled with a brass washer in order to minimize friction between the skewer and frame, ensuring a proper fit every time. Available in a plethora of vibrant colors, ideal for tuning the aesthetic of your current ride or next build, the 12 x 142 thru axle skewers from KCNC are a simple way of adding a dash of flair.
For complete sizing details on all of our thru axles please look HERE.
Model Interface Length Pitch Thread Weight
 E-Thru Flat 171mm 12 x 1.5 mm 18mm ~66g
 E-Thru Boost Flat 177mm 12 x 1.5 mm 15mm ~67g
 Maxle Flat 173mm 12 x 1.75 mm 21mm ~64g
 Maxle Boost Flat 180mm 12 x 1.75 mm 18mm ~66g
 Syntace X-12 Tapered 167mm 12 x 1.0 mm 19mm ~65g
 Material 6061 Aluminum
 Rod Material 7075 T6 Aluminum
Recommended Torque 15Nm
