KCNC Kasditor Disc Rotor
Article number: | 21-04-02 |
Availability: | In stock (8) |
The expert designers and machinists at KCNC are renowned for their ability to create utilitarian parts with a unique and bold aesthetic. In that same vein, allow us to introduce the Kasditor disc brake rotor. Borrowing from their previous tried and true minimalist rotor designs, KCNC has added a few more features to make the Kasditor even more appealing. By utilizing a beautifully machined 7075 aluminum spider and an aggressively laser cut rotor, the Kasditor inherits a handful of highly desirable characteristics. With the use of a 7075 alloy spider, each rotor is exceptionally light, while simultaneously remaining incredibly stiff to maintain constant and precise braking during long descents. Similar to a floating rotor, the 7075 spider additionally allows for better heat management for more reliable brake operation.
Compatibility
The KCNC Kasditor rotor is compatible with all 6 bolt ISO hub and brake designs, unless specified otherwise by the manufacturer.
Material | 7075 AL stainless |
Compatibility | 6 bolt ISO |
Rotor Thickness | 1.8 mm |
Includes | Rotor and hardware |
Weights | |
140 mm | 67 grams |
160 mm | 77 grams |
180 mm | 94 grams |
