KCNC Nordit Centerlock Disc Rotor
| Article number: | 022-03-01 |
Allow us to introduce KCNC's first centerlock rotor, the Nordit. By utilizing a beautifully machined 7075 aluminum spider and an aggressively laser cut rotor, the Nordit is a handsome rotor, that is exceptionally light while still remaining incredibly stiff to maintain constant and precise braking no matter where you ride. Similar to a floating rotor, the 7075 spider additionally allows for better heat management for more reliable brake operation.
COMPATIBILITY
The KCNC Nordit rotor is compatible with all centerlock hubs, unless specified otherwise by the manufacturer.
| Weight | |
| 140 mm | ~80g |
| 160 mm | ~90g |
| 180 mm | ~107g |
| Material | 7075 AL Stainless |
| Compatibility | Centerlock |
| Rotor Thickness | 1.8 mm |
| Includes | Rotor & Lockring |
